areomotive afpr install, return line?
2bar4g63t
156
Oct 29, 2002
Hi, im installing my areomotive afpr today and i have the line ran from the tank, to the inline filter, to the rail, to the side port on the afpr, ami right so far? it didnt come with instructions so im guessing . the bottom port i assume is for the return line, but on the old stock regulator, it had just a rubber hose with clamps to hold it onto a hardline, so how am I supposed to adapt the -6an fitting on the regulator to this hardline, or am i just missing the male -6an that i figured would be on the end of that hardline?? thnks
ok, that just sunk into my thick skull, so i shouldnt have even bothered with the -6an from the tank to the rail right?what a waste of my money. o well, live and learn.
at least it looks good huh...
There are adapter fittings so that you can connect an aftermarket filter to the stock feed line. Most people replace the filter, line from filter to rail, and then the regulator and the line from the regulator to the stock hard return line. Nothing wrong with upgrading the whole feed line, it has to be done eventually if you want to make big power.
  • Wanted 6 bolt NT water pipe
    • chrisman287
