install SBR iol return line
dwc4g63
84
Feb 25, 2005
Irwin, Pennsylvania
i just spent 110 dollars on a SBR stainless steel oil return line for my 90 gsx. i figured itd be pretty much a bolt in...nope nowhere close... no matter how long you cut the hose or bend it to,, it just doesnt fit right, i practiced fitted it like 10 times with regular rubber hose before ruining the stainless one..it pinches so bad just before it enters the oil pan , it only has one 45 degree fitting before entering the pan, others that ive seen use 2 or even just one 90 degree fitting, am i missing a fitting? too retarted to install this right, or does it really just fit like shit?? anyone have any experience with this piece?? im a big sbr fan so im a little surprised here.. i should add i have a stock pan and the stock little 14b and my stock hose fits just right( other than its cracked) so its not like anything is outa place...
Probably not your fault, ive never had good luck with SS return lines on our cars
  • Wanted 6 bolt NT water pipe
    • chrisman287
