Are these really FIC 750's?
Boomdeeze
2,146
395
Jul 5, 2009
Independence, Minnesota
I bought these off a guy that said they were FIC 750's but I though FIC's say Fuel Injector Clinic around them. These just have numbers etched into the side like serial numbers. I want to knowif they are real, if not im going to return them.
Mine look IDENTICAL and they are FIC 1000cc's. i think one of them at least (if not all) have FIC scratched into it, and yes some serial numbers. But in no way does it look professional (not that FIC isn't) but it looks like its scratched in there by hand.
So if they are PTE, how do they compare to FIC's? And were they worth $140? And mine dont have FIC on them anywhere just the serial numbers scratched in there.
I have a set of fic 850 and they are not exactly like yours.... they looks very similar execpt for the tip of the injectors. Fic's are fully metal with an horn shape at the very end. The PTE that i had in the past were identical at yours, tip was straight with a kind of black plastic sleeve.
I Cannot confirm that your injectors are fic or not, theses are just my observations
What are the numbers on the top of the injectors? By the way, pte, fic, rc, etc, dont make injectors. They use rochester/delphi, lucas, bosch, etc injectors. pte, and fic, both use rochester/delphi injectors for a lot of their products.
They are Delphi 75 lb / hr injectors. I have a set with the same part number. Nothing wrong with them. If they were FIC's version the part number would be FIC-0750. I used to own a set of those also. The part number on FIC injectors are hand scribed in them.
Yes there are still considered 750's. Advanced Fuel Injection (supported vender on here) can get you the seals. DSMLink forums has the dead time and global for them. FIC should still be able to get you the seals as well. Just tell them they're for Delphi injectors and give them the part number (17113742 ) don't worry about the 7275 part.
