are my RPM too high?
Spaniel1287
195
Jan 30, 2005
Daven, Iowa
WHen my 95 Talon FWD Turbo Automatic is in park, the RPM stays steady at 1500. It does not go up or down it just sits there. Ive sat in myc ar for 10 min straight to see if it woudl change ever and it never did. WHen i put the car in neutral and hold the brake it stays steady at aroudn 800 rpm. Is this a problem at all for when the car is in park. Should i turn that screw alittle to turn the RPM down for when im in park? Also if I turn the screw so taht my RPM goes down while im in park, will that affect the RPM if I'm in neutral?
Hmmm...my auto (camaro) will idle at the same spend in park or N then drop when its in gear. I have never seen an auto that wasn't like that.
