Are DNP manifolds 7CM
"7cm2" refers to the a/r ratio of the turbo's turbine housing in metric terms...it has nothing to do with the inlet size of the housing.
Instead, you should be asking what the diameter of the hole in the DNP manifold's outlet flange is in mm. It's likely either 52mm or 60mm.
