are all 91-94 t-cases the same spline ?
overboostedawd
101
May 26, 2006
north canton , Ohio
ok im geting told that i have a 22 spline and the 92+ are 23
i know the the auto t-case will not fit
is there difrence in the 3boltt vs 4bolt t-case ?
or are all 91-94 23 spline and will bolt up wiht no problems :thumb:
any one ? ive searched and i found a ton of threads on htis but not one that awnser my exact ?s please help guys im about to buy a transfer case but if its not the right one then im out 300$
Did you get the TC recall done to yours?? you might get a BRAND NEW free one from the dealer ...
From what I was reading most 5 speed manual AWD 90-91 have 22 spline..some AT awd have 23...then 92+ got only 23?
My 5 speed awd 1990 Eclipse has 22...
Chk it the hard way.....unmount the bad one( if you didn't already) and do a quick count :D just to be safe!
I would not buy a used TC for that money to start with..but good luck!
the t-case has 10 dyno pulls on it and its from slowboyracing so thats why im paying 300 hell of a good deal to me imo ah the recall cant get me in till jully 17th to long for me to wait
92awddsm said:
90 has 22 spline tc. 91-94 all came with the 23 spline tc. 90 is the only odd year.
Just to be sure, pull your tc off and count the splines.
this si definitely the case. i have a 90 and its a 22. took me forever to find a 90 trqanny. i suppose i could have gotten a newer trans w/ the transfer case. anyhow. this is correct
For future reference, it is very simple to swap output shafts and make your trans 22 or 23 spline to meet your x fer.
ok so from reading up on this early 91"s have the 22 and mid 91s have the 23 so i pulled mine off and counted its a 23 mine was made in jun so if anyone searching needs to know
also i got my new t-case to day and it will be on tomarrow thank good i miss booost thanks for the help guys
