Are all 90-92 tSI talons 6 bolt?
surel0ser
40
Jun 29, 2005
Kansas City, Missouri
Getting ready to order a new fly wheel with a new clutch. Are all talons 90-92 6 bolt?
Up until mid '92( april or may I believe) they were 6 bolts. after that point they went to 7 bolts. If you look at the front ( the side that faces the timing side of the motor) you will see a recess back on the face of the pan if it is 7 bolt. The six bolt is more or less a straight front.
Mike
If your engine is stock you should have a 6 bolt.
Checking the oil pan is the easiest way to tell which engine you have. VFAQ tells you how
HERE
HERE
Exactly...There are those pics I knew were out there.
Mike
