Anyone want to help.
Anyone want to help out alittle trying to get this this tuned alittle better. Not sure why I'm gettimg so much knock after 5.5k?? Any advise?
Is your walbro rewired?
E:dont drive your car again like this. loooking threw the log to see if anything seems to be messed up.
E2: You didn't calibrate your wideband, :nono: Do that then report back with another log, seems like your af/r's were actually 8.9 instead of around 10-11. :hmm:
E3: WOH, WHO TUNED THIS? You? Please start over from scratch and start off by calibrating the wideband then looking at ecmlink's tutorial videos, your tune right now is going to cause engine failure.
E4: You can keep the min/max octane tables, and the timing tables but reset everything else and calibrate the wide band!!
