anyone running this setup w/ the maft?
talontsi01
640
Oct 6, 2002
Detroit, Michigan
1g talon w/ 3" gm maf and maft.
I have the maft zeroed out right now because I'm on the stock fuel system with my 14b.
I'll be getting 550's and a walbro 190 put in soon, so what I was wondering is...what settings should i set it at when these two things go in? I know that every car is different, I'm just curious at what other people with the same (or similar) setup have theirs set at.
if you're on the stock system, the base should be set to 2 I believe. the rest can be zero'ed out. I have a 90 w/ FP rewire, 3" GM MAFT + exhaust. I think my settings are base 2, idle 5, mid 1, wot 1. I need to better tune the wot settings since I hit fuel cut at the top of 3rd.
You'll need to look at the appendix once you get 550's to find "ballpark" base setting. Set that and then go hwy driving (50-70) and adjust the base to where the high fuel trim + FT02 is around 100%.
check http://www.fullthrottletech.com/
the tuning guide is there as well as a support forum.
