Anyone Running Hahn Racecraft Turbo?
Then you should do more research Lol Hahn is definitely good but it's the same thing as any Mitsubishi Turbo they just change a few little things and put Hahn on it. Hahn holds the current record in the quarter mile for the turbo'd 420a. Your better off finding someone selling a 20g privately rather Then going through Hahn since it can be pricey. I just seen a billet extend tip 20g brand new in the classifieds for $620. But Yes it is a good Turbo to answer your question.
A Hahn 20G isn't a direct bolt-on for anything outside of maybe a Cyclone/Typhoon truck if the housings are clocked properly. T3 turbine housing, 3-bolt outlet flange on the turbine housing....needs adapters and other parts. Shitty whenever you can normally buy a direct-fit 20G for less money.
+1. this dsm life, its all starting to make sense... :aha:
