Anyone know who makes this?
MoparDSM
220
6
Jun 15, 2007
Stafford Springs, Connecticut
I have been looking for who makes this spark plug well cover without much success. Does anyone know who makes it or where I could buy it from?
Thanks in advance.
Whew, that was fast! You rock, thanks!
rre is correct, i have the same one.
only problem is where the plug wires come out, the bottom corner is sharp and cuts into your wires... looks cool, but this edge needs to be addressed.
Oh wow, thanks for the heads up!
If your going just for the cosmetic look of the RRE cover. Should get yourself a Coil-on-plug setup and have looks and Functionabilty. Plus it eliminates your stock coil pack. Really does make your engine look better and makes your car run better. I dropped 200 RPM on idle after installing the Buscher Racing COP setup and of coarse new NGK copper spark plugs think they were the br6's. Either way whatever works best for your setup is all that matters.:thumb:
Thanks. I was asking for my boyfriend who isn't registered on here. I know he has thought about going COP, but then thought would be overkill for his setup. He is relatively lightly modded, even still on the stock 187,xxx mile head and block. Perhaps at some point down the road.
Please don't spread bad information. It's widely known on here that our stock ignition system is far better than a COP setup. The only time I would say you could effectively get a COP setup is if you had an aftermarket CDI (Dynatek, AEM, etc.). Otherwise, you're just going to hurt your system.
Well, that saved me some research, thanks! I thought I had read some time ago that this was the case, but I couldn't remember exactly why I wasn't going to use a COP setup.
The OEM ignition system function is wasted spark with 2 coil drivers, so it will still fire 2 plugs, splitting the coil by doing COP splits the coil energy which is why it's useless.
True 4 coil driver capacitive discharge setup is much more ideal which is what cop is suppose to mimic.
