Anyone know the wattage or how to find out the wattage?
yerryjusko
May 15, 2005
edison, New Jersey
My cousin jus gave me this AMP and he wasn`t sure how much wattage it could handle...does anyone know the wattage or how to find out?
The amps an AUDIOBAHN (A2401Q)
A simple google search can tell you anything. :nono:
AudioBahn A2401Q Review
Features of the AudioBahn A2401Q include:
Amplifier Type - Dual Channel
Power Output:
RMS Power at 2 Ohms - 1 W x 100
RMS Power at 4 Ohms - .02 W x 100
Performance:
Signal to Noise Ratio - 140 dB
Bass Boost Frequency - 30 Hz
THD at Rated RMS Power - 750 %
Dimensions:
Width 45 in. Height 2 in.
Other Features:
Input Voltage - 18 volt
Power Output:
Performance:
Dimensions:
Other Features:
I call BS on the specs above. S/N ratio 140, THD 750% (that's a LOT of distortion), 100W RMS at 2 Ohms (1Wx100) and 2W RMS at 4 Ohms (0.02Wx100). If the 0.02W was a typo and is supposed to be 0.2 watts, that would be 50Watts RMS at 4 Ohms x 2 at 18Volt input. An amp that is 45 inches wide and only puts out 50Watts RMS WTF
At 12Volts or 14.4Volts that would probably be around 25Watts RMS per channel. :notgood: There are headunits out on the market that put out 25Watts RMS.
These are the specs that I found on the internet (after searching around for about 20 minutes):
Class A/B MOSFET Circuitry
2 Ohm Stereo Stable
Bridgeable Into 4 Ohm
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Variable 18dB Hi-pass Crossover: 50Hz - 750Hz
Variable 18dB Low-pass Crossover: 50Hz - 120Hz
Bass boost @ 45Hz: 0-18db
Subsonic Filter: 20Hz - 50Hz
3-way Protection Circuitry: Thermal, Short Circuit and Overload
Dimensions: 12-3/4"W x 2-3/8"H x 10"D
560W Max Power
2 x 100W RMS @ 4 Ohm
2 x 140W RMS @ 2 Ohm
1 x 280W RMS @ 4 Ohm
Now look at the 2 specs. The first specs state that your amplifier is 45 inches wide and 2 inches high :rolleyes: . The second specs state your amp is 12-3/4"W x 2-3/8"H x 10"D.
It seems like someone just posted those specs and it kept getting distributed around the internet. :mad: Your best bet is to call Audiobahn Customer Service and see if you can get the specs from them. :thumb:
I found another set of specs matching the ones I gave earlier:
Audiobahn A2401Q
100W x 2 Car Amplifier $329.99
140W x 2 into 2 ohms stereo
280W x 1 into 4 ohms stereo
Variable high-pass/low-pass crossover
Signal-to-noise ratio >100dB
Source: http://www.caraudio3000.com/SubWepPages/Amplifiers/2-Channels Amp.htm
The first set of specs (found on Google) are the same as here on this link - http://www.recommendedbuys.com/electronics/car-amplifiers/audiobahn-a2401q.htm
This is the picture from the link above where the specs state the amp is 45 inches wide. :sneaky: The specs contradict the review. The picture above looks like it is 12-3/4"W x 2-3/8"H x 10"D.
