tommiman
- 273
- 5
- Aug 31, 2004
Vaughan,
Anyone know how these 2 connect? What am I missing? See the before and after.
He's right ^^^ On my car this is the connector to the knock sensor. The wires go from the sensor to the missing connector that mounts on the metal tab. The connector you have in the photo plugs into missing connector. The knock sensor is underneath the intake manifold runner for #2 cylinder. Your missing connector is under the manifold, probably near the EGR valve.95redgsx said:Those 2 pieces do not connect , the other part of that conector mounts to the metal mounting tab . that being said I'm not exactly shure what connector that is but it looks like it might be for the knock sensor if thats the case the other connector is probably under the intake manifold somewhere
toojung2die said:He's right ^^^ On my car this is the connector to the knock sensor. The wires go from the sensor to the missing connector that mounts on the metal tab. The connector you have in the photo plugs into missing connector. The knock sensor is underneath the intake manifold runner for #2 cylinder. Your missing connector is under the manifold, probably near the EGR valve.
tommiman said:I'm a little confused here. So do these two connect but are missing a piece inbetween or this connector does not plug onto this metal tab but somewhere else?
The missing connector is under the intake manifold???
Please clarify.
lookin4dsm said:The other connector popped off that metal piece (bottom image of second picture, circled in red) and fell down somewhere in the back of the motor. The knock sensor is on the back side of the engine near the #2 cylinder. Follow the wires coming from it and they should end at the connector you are trying to find. Slide it on the metal piece (bottom image of second picture, circled in red) then connect it to other connector (top image of second picture, circled in red).
Mike
If you start by finding the knock sensor and follow the wire coming off it you will find the piece (it's a connector) you're looking for at the other end of the wire. There's no way to know exactly where it fell but I was guessing you would find it near the EGR valve because that's where the wire runs on my 2g. It looks similar to the connector circled in red in your first photo and plugs into that connector.tommiman said:I got it. I'm not sure why you're saying it would end up where the knock sensor connects to the block? Wouldn't it land in a random place at the bottom of the engine?
Anyone know what this piece looks like so I know what I'm looking for?
toojung2die said:If you start by finding the knock sensor and follow the wire coming off it you will find the piece (it's a connector) you're looking for at the other end of the wire. There's no way to know exactly where it fell but I was guessing you would find it near the EGR valve because that's where the wire runs on my 2g. It looks similar to the connector circled in red in your first photo and plugs into that connector.
tommiman said:So from what I understand is that you are saying is that it slid down the wiring harness from the connector to the knock sensor.
Okay, let's try some pictures. The first photo is both connectors together and clipped to the metal tab. The second picture is the connectors taken apart and the piece you are looking for highlighted in yellow. The wires from the highlighted piece go under the intake manifold to the knock sensor. I hope this helps.tommiman said:Does anyone have a pic of this missing piece?
lookin4dsm said:Look in the "valley" area (under the fuel rail, above the intake manifold) to see if it fell down in that area. If you can't find it there, jack up the car and locate the knock sensor from underneath. Follow the wire from the sensor and your missing connector will be at the other end.
Mike
tommiman said:The thing I forgot to mention is that I had the head and manifolds off. The thing could be anywhere.
lookin4dsm said:Did you remove the knock sensor from the back of the motor? If the sensor is still there, just follow the wire to the missing connector. The wire probably has the black plastic protector around it. When you removed the intake manifold, it probably fell down towards the back of the engine.
See pictures here: http://www.plymouthlaser.com/knock.htm
Mike
tommiman said:I removed the two bolts from the intake manifold stay so the knock sensor did stay on.
If your head is off finding the knock sensor is easy. Use the pictures In the link lookin4dsm posted. It shows the exact position of the knock sensor. You won't have to get under the car because it will be clearly visible from the top on the firewall side of the block. You'll never have a clearer view of the knock sensor. Now is the best time to get a new one. They go bad with age.tommiman said:The thing I forgot to mention is that I had the head and manifolds off. The thing could be anywhere.
Wait a minute... You know enough about your car to remove the head and manifolds and you're asking for help to find your knock sensor connector??? I think I just realized that tugging sensation I was feeling is someone pulling my chain.tommiman said:The thing I forgot to mention is that I had the head and manifolds off. The thing could be anywhere.
toojung2die said:I think I just realized that tugging sensation I was feeling is someone pulling my chain.
