ANYONE IN SAN DIEGO WANT TO HELP with BLT
yeti-gvr4
422
Dec 23, 2010
san diego, California
I CANT pinpoint my leak it wont even build boost the blt gauge just stays at 0
ive used soapy water but no bubbles!?:confused:
The blt is I got a 3" to 2" adapter hooked up to my turbo inlet.and have the regulater set all the way up to 100 (I started at 20lbs) and it stil want even go over the zero on the gauge ....
The only way I can check is I take off one of the IC couplers and put my hand on the end of the pipe and check for leaks in between
I think I'll manke a plug for the other side so I don't have to use my hand
If you can't build any pressure you have one serious leak. You should be able to hear the air rushing out somewhere. Find that somewhere and that's your leak.
I can't hear air rushing out anywhere so I m just gonna test each coupler and so on.
Bahahaha, this is great.
The guy who got argumentative and cocky with all the knowledgeable members when they told him he couldn't build a 500whp car for $500 is so informed he can't figure out a BLT.
I could probably solve this for you instantly, but because you're so brilliant i'll give you a hint about what you're likely doing wrong and let you figure it out.
Hint: Crank position.
