anyone have pics of normal gear wear compared to excess?
97grnrs
124
Nov 3, 2004
reading, Pennsylvania
im rebuilding my spare trans and it never had any grinds and shifted smoothly beside a bit notchy 3rd and 4th once in a while , im replacing 3/4 synchro and a few bearings , my 2nd gear looks a bit worn though, the teeth on the slider are a bit rounder than they should be along with some wear signs on the few other pieces. i cleaned off any burrs i found on all the parts but seeing this im suprised i didnt have any problems shifting ever. i cant afford more parts right now so its going back how it was but id like to see a pic of a normally worn and ok gear set vs an extremely worn one thats gonna cause problems, google isnt really finding anything useful .
thats real professional of a business. ive done nothing to you to deserve that response but its ok. TMZ perf is on the ball and will be getting any business i may have .
Rounded off teeth on the gear will degrade the shift quality. The slider is usually worn more. As long as they aren't completely worn off it will be ok. Post a picture. I've been running stuff in my car, that shops would throw away, and it shifts pretty good. I shift at 9k.
Most important thing is having a good synchro, and not having a dragging clutch. I prefer to use the older fiber lined synhro's where I can't run a double syncho. I cut a diagonal slot in the fiber so it sheds the gear oil away. They don't last as long like this tho.
well i see someone deleted their post.... and i went ahead and put the trans in. it shifts smoothly so i guess the wear is just normal otherwise id be crunching right about now..
