Anyone have a HAFE Manifold?
Side_Show
326
Mar 22, 2008
W.N.Y., New Jersey
Well i was justing looking around on some manifolds that i might use on the near future for my laser. If anyone does use it, do you think it's just as good or better than a FP Manifold. I was thinking of upgrading to a E3 16g and figure i get a decent manifold with a wastegate flange on it.
I've got one with a TD06H 20G on it, full spool around 4000 rpm. Works fine, and you don't have to worry about it cracking like the SBR manifold. One thing to watch out for on this manifold is the crappy threads on the waste gate mounting flange, chase them with the correct tap before trying to put the wastegate on.
what made you pick the HAFE over the FP Manifold, was it the flow difference or the fact the HAFE has the flange for the external wastegate. I do like the fact that the HAFE is SS so there's no worry about rust.
What psi is your full boost?
I have one and i bought it for the external waste gate feature but only the FP manifold has the number 4 runner redirected where when they fire there not firing into each other, they have a signature shape and design, but for the money you cant go wrong with the HAFE manifold plus it wont rust because its cast SS instead of nickel or iron
The HAFE is basically just a stock design with a flange cast for an external wastegate. The FP is the only stock style bolt on mani for us that actually has a properly designed collector area, that fires the exhaust pulses down into the turbine inlet. The FP mani will be the better performing/flowing between the two.
