anyone else feel a shift/clunk once in a while when pressing clutch
97grnrs
124
Nov 3, 2004
reading, Pennsylvania
once in a while when i press my clutch i can feel a slight knock/ thump in the pedal.its only one little thump not multiple i dont know if its coming from the motor or what , its not the pedal assembly or the slave/fork assembly. my first thought was maybe its crank movement cause i can move the pulley in and out a bit but the endplay is still in spec at .008 so i doubt its that. the idle or nothing else changes i just feel it every once in a while mainly when coasting to a stop just using the brakes then applying clutch to go into 1st or reverse. i try to mimic it but it only does it at random.
Maybe its the clutch binding on the spline? i thought i remember seeing some rubber plugs on the bell housing of the tranny. maybe you can try getting some lube up in there.... coulndt hurt as long as you dont get to much on the clutch.
