Another question but about boost
scrim016
Oct 17, 2004
Pittsburgh, Pennsylvania
i got a hahn stage 2 with all stock internals. seems like when im driving then hit the gas hard it takes awhile to get power. The boost gauge will read 6psi but i feel nothing for a few seconds then it will slowly start to get more power. Anyone have this problem or a solution for it?
Thank you
Yes, what /\/\/\/\/\/\ said. Makes sure that there are no boost leaks. Check all of your silicone couplers and make sure that they are clamped on well. Also make sure that you you have no exhaust leaks, although you should be able to tell if you do by hearing.
The S16G should spool by 3-4K rpm's. Of course if you have the S20G, there will be a bit more lag.
