2G Another no reverse
dyablo
250
Jan 22, 2005
Indio, California
99 GSX was running fine then the engine blew. Replaced the block and installed end clutch kit along with ipt shift kit.
Put it all back fired it up and no reverse. Shifts to second fine third now slips but catches with OD off.
With OD on I believe third does not even catch just free revs.
This leads me to believe I messed up the end clutch kit.
So the question is would a bad end clutch kit assembly cause a no reverse?
Checked gear selector in trans and hole lines up. Removed VB again to double everything. O ring is there to. Wtf am I doing wrong?
