Another logging question.
bluetlr2001
510
6
Mar 6, 2006
Louisville, Tennessee
Ok im new to logging. First off im not sure which are the best to log im using obd gauge software. So far im logging rpm,tps,timing,o2-1, And my short and long fuel trims. Another question I have is today i was watching my logger and in third and fourth it felt like i hit a small fuel cut and my timing jumped form 33 to 3:beatentodeath: what does that mean, im pretty sure it aint good.
Well it could be your gettin alot of knock. And you can't hit "small fuel cut" when you do you'll know it because you'll probably hit your face off the steering wheel.
Also, Are you running a GM maft setup because I see in your profile that you have a RFL. And bumping threads is a good way to get them closed.
-Adam
You shouldn't be hitting fuel cut with a 190 and a rewire. If your still running the T25 18psi is a little much for it. Also when doing boost leak tests you should spray soapy water because just cause you can't hear it doesn't mean theres not any leaks.
-Adam
Nope wish i was running a gm maft but dont have the money yet. But i know its susposed to be better to recurculate the bov but i tried it with my greddy s and couldnt tell a difference. And ill try the soapy water trick tomorrow. And I didnt know about bumping the threads thanks for letting me know that to. And is there a way to check to find out if it is knock. And i know how fuel cut feels and its almost like that just not as bad. And again thanks for letting me know about buming th threads.
The fuel cut feel might be because your not recirculating and your running rich. Im not sure how to read knock on 2g's maybe someone else can chime in.
-Adam
The make a kit i think bu ti could be wrong but i do still have my greddy that ill throw on it for now and see what happens. And another thing dont know if you know about this but i was reading and most peoples timing ive seen runs around 14-16 at wot. And mine runs around 14 normal and moves up to 33-34 at wot.
you sure? WTF
can you post a copy of your log for us to see? :thumb:
Heres a log from tonight at 18psi. 2-4 gear run, let out in 4th
Rpm Timing fuel trim o2
1360 6 0 800
3374 3 0 980
4504 0 0 980
5188 10 0 700
3976 6 0 1020
4400 20 0 700
2984 32 -10 680
2508 31 -16 740
2024 28 -16 860
1640 22 -14 20
Is this good or bad.
Looks absolutely terrible.
Logs aren't performed like that usually either.
When making a log (and be safe about it please), be rolling in 3rd at around 2500rpm and then just gun it. Wind out 3rd gear until 6500-7000 rpm and back off. Log only rpm, timing, tps, and 02 voltage.
Post back and we'll better be able to help you.
I suggest you run no more than 15psi as it is though. Start there and we'll see how we can help.
good luck and definitely post back! :thumb:
Ok so i done a log like you said and here it is. And i hit fuel cut a couple of times doing this.
Rpms timing tps o2
2256 26 20 740
2516 1 74 920
3032 1 85 920
3656 4 100 940
4304 7 100 980
4920 8 100 980
5244 10 100 1000
5652 12 100 1000
6000 14 100 1000
6284 31 5 560
so good or bad
Ok heres my recent log ive done at 15psi. I think theres alot of knock but im still new to the logger so help me out here. And i know im running rich to so dont know if thats causing knock either. And youll see were my rpms dropped i had to back out the throllte a little and ease back in because it just nosed over.
Rpm Timing o2
2380 21 .880
2696 2 .920
3176 3 .940
3584 -6 .940
3800 -4 .000
4084 -1 .980
4532 1 1.000
5024 4 1.000
4940 7 1.000
5252 9 1.020
5500 9 1.020
5712 11 1.020
5932 12 1.000
6132 14 1.000
Rpm Timing o2
2380 21 .880
2696 2 .920
3176 3 .940
3584 -6 .940
3800 -4 .000
4084 -1 .980
4532 1 1.000
5024 4 1.000
4940 7 1.000
5252 9 1.020
5500 9 1.020
5712 11 1.020
5932 12 1.000
6132 14 1.000
Your timing is -6..... I think your probably geting alot of knock right when you go WOT. Turn the boost down and try another one. Also check base timing
-Adam
I was going to check base timing but cant seem to find the plug thats suspossed to be behind the battery to ground to set the timing. Plus ive tried it at 12psi and it still goes to negative timing. Do you think it could be a bad knock sensor or just to sensitive.
I believe if its bad then there should be some "goo" or something coming out of it. check for that.
You dont have bigger injectors do you? Did you ever find a way to recirculate your BOV. I dont see how you could be running that rich on stock injectors.
-Adam
