Another Exhaust question
xlMcMlx DsM
276
Nov 7, 2005
Madison, Wisconsin
ok, i've heard that an 02 eliminator helps stop boost creep. What is the 02 eliminator? is it in the down pipe because ive seen thsoe in the parts catalog. And if i were to get an exhaust w/ all the goods(new 02 housing, or turbo back system, etc.) what combinations of those would be good and which would be better? thanks
An O2 eliminator only eliminates the connection between the stock O2 housing and the downpipe. On my car, it provides a 3" pipe from the turbo to the exhaust.
If you are trying to help boost creep, upgrading your exhaust will not help you. You should try to port out your turbine housing around the wastegate and post back.
Generally, as you upgrade to a better flowing exhaust, you will experience more extreme cases of boost creep.
