Another dash light question...
viperlp01
2,518
80
Oct 9, 2006
Kalamazoo, Michigan
So i was drving home thursday night from class and i had a electrical fire in my car.. Everything shut off(except car).. I pulled over immediately and ripped my radio out and saw the green wire with white stripe and one silver dot fried to the copper. Well I traced all the wires and found that at my fuse box the wire meets the tail lamp relay. That irrelevant. I fixed all the burnt wires so it seems good.. No more fires LOL :thumb:
Now my problem. I can turn my dash lights into the running light position and my tails, runners, and dash come on... I turn on my actual lights and the lights come on but nothing else does...
Ya so i went out and started messing around.. I figured out it is the light switch I hope :pray:.. If i turn the lights on the dash lights will come on for a sec and go off when the headlights come on.. I can mess with the switch and stuff doesn't act right. I hope this is a semi easy fix, The assembly looks complex..
