Annoying timing problems...HELP!!
empie1
1,063
5
Dec 30, 2004
albany, New York
I have owned a decent amount of cars, including 2 other dsms, and have never had issues setting base timing.My current car, 2g tsi, has always been a bi*** to time.But, i still managed to get it.However, since i swapped in a 6bolt block (with a 7 bolt head), I have yet to set the timing correctly.Its ALWAYS off a tooth.If i set the exhaust tooth off 1 to compensate for its movement, it wont move.f i line the cams perfect from the beginning, the exhaust rolls off a toothI really dont get what im doing wrong and its so aggrivating i want to sell the car. I reused the 7 bolt crank sprocket, could that be why they never line up?Other than that, I am stumped...any help would be appreciated.thanks
mike
I have had the same problem with the cam gears.
It's kind of a pain in the ass but it works. Line the gears up dead straight, then have a buddy hold the exhaust cam 1/2 a tooth back as you tension the belt. I've gotten the thing to stick 1/2 a tooth off by myself but it's a lot easier with a partner. This has worked for me several times, hopefully it will help you.
Aloha
Get a 6 bolt crank sprocket and pulley, and check to see if they are the same.
