Amp going out?
Alex Bland
666
3
Jul 2, 2008
Seabeck, Washington
Ok so i took off the kick pannels (because all 4 of my front speakers were popping like a wire is touching something non-stop like 4-5 times a second) So i took a screw driver and was tapping on my amp with it and it started to play music threw the speakers. i checked the wiers from my amp to the radio. i dont know.. its stock amp
it is most likely a cold solder joint inside of the amp itself on the bottom of the circuit ,or a leaking capasitor or dryed out . I don,t know how much you know about electronics but you could fix it very easily with a good soldering iron . or take it to a repair shop if you want to keep using it .
