Aluminum radiator for 2g nt
Inlet and outlet for coolant and mounting locations are different. If you compare pictures you'll see what i mean.
Check DGR, Megan, or Fluidyne for radiators and silicone hoses for a good well made aluminum radiator.
hope this helps
:thumb:Thanks i noticed the inlet an all were different i just didnt no if you could get hose to make them fit but alright im just looking for a full aluminum radiator cause i crack the bottom on mine cause of the plastic but ill check them out an thanks again
if i use flexible radiator hose then could i use the 2g turboed radiator?!
