Alternator Swap?
AdrianPria
Aug 28, 2012
Caracas, South America
Hello DSM'ers I wanna know if i can swap another mitsubishi alternator into my dsm (7bolt) My alternator is not working I changed the Stator, Voltage Regulator, Bearings and the Diode Set, Tested the Rotor (It's fine) and the alternator still not working :cry: I can't find another 4G63 Alternator so, can i Swap a
Mirage 1.8 4G93
Lancer 1.6 / 2.0 2000-2007 4G94
Galant 1997-2001 6A13
Any of those?
The only problem is the engine bracket lenght of those alternators is 2.5" while the 4G63 is 3"
vs
Any suggestion? Thanks very much.
The bracket being .5" short definetly will not work bro. Why not order a good one from a vendor on here or buy one of the classifieds I've seen tons, you can even get a upgraded galant 90amp or do the Saturn swap. Tons of options bro tons I even have a few extra if you need one that bad and don't wanna buy new. Lmk shootz
The ship will be to Miami hehe, but I solved the problem, I cut the 2 ECU wires and now the alternator is working properly. He's sending 13.9V / 14.1V
I did a write up on the galant alternator swap. With part numbers and places to buy, you will find it in the tech article section
