alternate water feed?
nickrule99
502
Jun 14, 2003
Greenfield, Massachusetts
I ran into a problem installing a 16g on my 6 bolt block, with a 2g head, water pipe, and thermostat housing. The drain still hooks up to the water pipe ok, but I need to find another feed line because I dont have the feed from the block. Now I see why I should have used a 1g water pipe. Do I have any alternatives to finding a 1g pipe somewhere? What if I were to "t" off the line feeding the oil filter housing? I need to get this engine back in the car.. so any suggustions would be great.
Thanks guys.
-Nick
You can tee off one of the waterlines that are coming off your thermostat housing.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
