jeremy19984g63
- 353
- 7
- Oct 24, 2005
chilhowie,
Virginia
I found a donor 92 gsx real cheap, was wanting to know if and what parts could be used in converting my 98 gst to all wheel drive?
Merkles said:i heard the spyders are built on the AWD frame so would there need to be any welding for the driveshaft brackets or are there spots there for them already?
sonicnofadz said:10k for a 2g awd? Right...I see 95 GSX's going for 5k or less on autotrader all the time. Do yourself a favor and sell your fwd. Even if you successfully do the swap, the chassis still won't be as stiff as the 2G awd, the whole thing will be just a big hack. You will save both time and money buying a GSX, and your car won't be a ghetto-fied 2G FWD chassis.
98eclipseRS said:Get a clue kid, 2gs are not 500$ 1g's where the chasis are different between the fwd and awd. The only difference between the fwd and the awd are the rear subframe and the obvious drivetrain diffrences. If you take the time to do the conversion correctly you will have no different a car than if you were to buy an awd out right. And by take the time I mean weld in bolt holders for the front subframe bolts. Weld sheetmetal over the old fuel pump assebly hole and cut a new one for the awd fuel tank along with using the awd fuel pump sending unit cover.
GreddyGst said:ugly Automatics 95-96 cars go for under 5k... We are talking about a 97-99 5speed under 100k miles. Those go for higher, also prices depend where you live.
sonicnofadz said:Sell your car and buy a GSX. You will save both time and money.
