all dp's the same??
They are not the same, but they are similar. You can buy a 2G down pipe and make it fit, or you can buy a 1G DP and it will just bolt on. If you do it right you will only have to do it once. If you look around I am sure you can find the actual DP you want.
sounds good thanks for clearing that up, ill got what was built for my car
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
