Spln_Hrd
- 1,707
- 8
- Oct 20, 2003
Hastings,
Nebraska
I just had the car aligned today, here are my final alignment readings. This is a 95 GS-T.
L Caster 4.3
R Caster 4.6
Front L Camber -1.3
Front R Camber -1.9
Front L Toe .00
Front R Toe .00
Rear L Camber .5
Rear R Camber -.4
Rear L Toe .15
Rear R Toe -.35
Thrust angle .3
I did the DIY rear camber adjustment.
I placed 8 washers behind each A-arm total of 32 each side. It was approximately 7/16 of an inch that I brought out the A-arms in the rear. How many do I need to remove in order to get it right? Also the rear right toe is in need of a bushing (the mechanic said) in order to get it within spec. Also on the front camber, what kit would you reccomend to adjust it. I have tokico blue shocks with red tokico springs ( I didn't purchase them so Im not quite sure about shocks and springs other than brand).
Any input would be highly appreciated.
L Caster 4.3
R Caster 4.6
Front L Camber -1.3
Front R Camber -1.9
Front L Toe .00
Front R Toe .00
Rear L Camber .5
Rear R Camber -.4
Rear L Toe .15
Rear R Toe -.35
Thrust angle .3
