Alignment ? after new springs and struts
Stoner
515
4
Jul 29, 2003
North Vernon, Indiana
I just put a set of eibach pro kit springs and kyb agx struts on my 95 awd talon. I have read different things about getting camber adjustment kits so that the car can be aligned correctly.
This is a dailey driver not a full blown drag car so I am not concerend with camber during a launch, I just want the tires to wear well and the alignment to be right.
What do I need to get before I visit the alignment shop?
Do I have to get the camber kit for the rear only or will i need one for the front also.
Thanks for all the help,
Ben :confused:
From what I've seen with friends with 2gs, the rear definetly needs a camber kit as you more than likely know. IMO I would get a front camber kit also, this will allow you to adjust your tire settings as you see fit to optimize tread wear.
