ECMlink AirflowPerRev
dudeX
126
12
Jun 14, 2011
Surprise, Arizona
Alright, my airflowperrev hovers around .20gm/rev. From what I've seen I need to be around .25 but cant seem to get there. I have no clue what I'm doing wrong here. Trying to dial in my new FIC 1120's and cant seem to get past the first step. Attached is a short idle log. Totally lost here.
I changed all the sliders up to 100hz to 0% during the log. It got the gm/rev up to .22 for most of the log but not to the .25 I'm looking for. It seems most people are trying to come down from .30gm/rev. Any idea why I'm having trouble going up?
Is your valve cover vented to the atmosphere?
Do you have any boost leaks?
Found another quote from Dave that might be of some help:
A negative average CombinedFT at idle despite a low AirflowPerRev suggests that either the injector settings are a bit off, probably a higher than needed deadtime adjustment value, or the fuel pressure regulator is being overrun at idle by the rewired Walbro. If the FPR is being overrun, the simplest configuration fix is to just run a lower than actual AirflowPerRev reading at idle.
And one from Tom:
Just keep in mind that getting AirflowPerRev to a specific value is something you should consider doing if you're having other problems like the low fuel trims being out of line or something like that.
Then again, how do you know if whatever settings you're using are "correct"?
What effect would a vented valve cover had on air flow per rev? Not trying to thread jack just curious.
Anything that provides an alternative unmetered path for air to reach the cylinders will lower the AirflowPerRev.
