Air/fuel ratio Guage hook-up
DSM JIM 98
59
May 26, 2011
Mount Holly, North Carolina
Can somebody tell me where to hook up a Glowshift Air/ruel ratio guage(narrowband) on a 1998 Mitsubishi Eclipse GS w/ the 420a motor, Plus the ecu is under the hood. just need to know where to hook the wires up. Remeber its a narrowband not a wideband. Thx.
Have you tried vfaq for the pinouts, before i got my wideband i used one i found the wire on the ecu using vfaq.com.
No problem not sure about the ecu for your car i wired the nb into that wire then got rid of it but good luck with your project.
Yeah, YOUR ECU is in the engine bay, you are going to have to find a "Chilton's" or "Haynes" Manual. Either that or run a tap from one of the black wires from your O2 Sensor.
2g N/T DSMs have the ecu in the engine bay right infront of the battery...sorry i couldnt be more helpful then that LOL
