Air compressor for boost leak
Time4the16G
33
Jul 18, 2009
Rialto, California
I need an inexpensive air compressor that will support a boost leak test. Does anyone have some suggestion? im looking to spend 50-100 if thats possible. I have no idea what the maximum psi should be... Assuming im running my car normally, would i need an air compressor ranging from 14-20 psi?? that seems very low... I think my hand held air mattress inflator pumps out more psi than that. So would that handle a test?? Is a 1 gallon tank large enough? and are inflators and compressor basically the same thing?
Air inflator im considering
BLACK & DECKER Air Station Portable Inflator - ASI300 at The Home Depot
Compressor im considering
http://www.sears.com/shc/s/p_10153_...e+air+compressor&sid=K-on-Sx20k061224x0000002
Husky Husky 1.5 gallon Air Scout Compressor - 41214 at The Home Depot
Any little compressor should work, it doesn'y have to be an industrial one. A little roofing compressor would work. I only pressurized mine to like 30PSI when I did it.
I don't think an inflator is the same because it doesn't compress air, it just moves it.
  • Wanted 6 bolt NT water pipe
    • chrisman287
