Aftermarket cams with stock T-25
calico
156
Jun 19, 2006
Newport News, Virginia
Is it worth it to run aftermarket cams with the stock T-25? If so what would be some good grinds? I am curious because it may be awhile before i am able to upgrade to an Evo 3 16g.
If you install them, don't expect any significant gains while you still have that T25 in there. That turbo runs out of steam around 6K with stock cams. If you put aftermarket one on there, you won't be helping a turbo that's already breathless at redline. If you can buy the cams, leave them in the box until you get a larger turbo that can really take advantage of larger camshafts.
I'm running 264/272 HKS cams on my stock T-25 and there was a nice gain from from 3k all the way to redline.
Unless you are getting free cams you can get a used turbo for a good deal. If price is a concern get a 14b and some mods. You will notice more of a difference with some upgrades then cams on a T-25 alone.
Did you do a before and after dyno? I am interested in the dks versions of these for $350.
