afr ??? please help
lou schmouder
271
Jun 17, 2008
dalton, Georgia
please help not sure whats going on. No boost leaks. fpr @ 44 psi . Injectors and dead time set right .Commpresion is good.Plugs are gapped correct. But cant shake these 17-1 and 18-1 afr .I also posted log mabe I am missing something . This car has no tune also
please help
You don't have a wideband logged. You should not be trying to tune off your AFRatioEstimate.
Get a wideband and log it so we can see your actual values. Also go to ecmlink.com and fallow their videos they have this will help you get setup.
This is where you should start checking for leaks the whole way through. Also, if your running a maf make sure it's working properly. There's a chance it could be misreading the amount of air your bringing in and throwing a ton of fuel at it.
