jacobbyrd
- 0
- Feb 10, 2011
north wilkesbor,
North Carolina
I just finished installing my AEM AFPR, which I got along with the install kit from MAPerformance.
When I started the car, I went to go and adjust the pressure, and as I took the vacuum line off the AFPR, I noticed that the gauge was reading my pressure a little over 50 PSI. I went to rotate the screw up top counter clockwise, and soon realized that no matter how I adjust that screw, the pressure remains constant, around 51 PSI. The only time the gauge moved was when I hooked the vacuum back up, and pulled the throttle, and noticed that it dropped to the upper 40s, but only with throttle.
I triple checked all vacuum lines, and my installation.
What gives?
What gives?
