AFPR Bottom not drilled, normal?
VPrime
802
3
Feb 5, 2006
Lonon, ON, Canada
Hey I got an AFPR (not sure what kind, but looks like an aermotive) but the bottom port is does not go all the way through
Could I just use the 2 side ports?
This FPR has 3 ports in total, 2 on the sides and one on the bottom.
The 2 on the sides are all the way through. If I blow through either side no air comes out the bottom port...
Are all 3 ports supposed to do the same thing? If that is the case I can just use the 2 side ports and be done with it.
Dude...
the side side ports are "in" ports. You will have to cap one of them.
The bottim port is the "out" port for return fuel.
You can blow through it probably because the diaphram/spring has no pressure on it yet.
Dude...
ok, was just making sure about the side ports... Is this bottom port normal then? Is it supposed to be like that?
