afc problems
The actual wiring harness? Try calling an authorized dealer and see how much it would cost to buy one, or you can try ebay.
If you are worried about not having the harness for your AFC, and not being able to hook it up, its not a problem. As long as you have the wires that come out of the box your fine. All the harness does is extends those wires to make it easier to wire in the AFC with a clip for removal. All you need to do is cut the harness clip off and hook it up. Te only problem is that you would have to mount it before you wire it in, and if you want to remove it all you have to do is cut the wires, because you wont be able to unplug it. I worked for a speed shop, and we were a dealer for Apexi'. I think its going to be hard to get that harness without the box. - good luck -
