AFC 1 help needed
way2slowtalon
147
Oct 24, 2004
Newington, Connecticut
I own a 90 talon and have this thing solderd perfect, it turns on. But tps,and rpm dont work. Plus it will run for 5 seconds and pop up a cel. Any ideas guys? Dont think its a wiring issue.
Oh i have a 2g MAS on it, would that mean its not Karmen?
THANKS!
2g mas is still karman.
did you set the 2 numbers that determine your car and mas type wrong? in the back of the manual for the afc theres a list of the numbers for each car and mas type. its in the menu where you put in the number of cylnders your car has, ect (sorry, my 91 was recently totaled and i cant go and look to tell you exactly what menu and setting right now). it would be the same mas number as stock.
i forgot to set these when i put a vafc in my friends prelude, adjusting the afc had no effect and it didnt run right. we thought i messed up the instalation cause the wiring diagram manual was comletely in japanese. but i foirgot to set those 2 numbers, and it ran fine after setting them correctly.
