AF Leak
wings9191
212
Nov 23, 2003
Lima, Ohio
95 Talon turbo
I have a leak of my Anti freeze.
I thought it might be the hose coming out of the filter cooler.
Got it replaced and it's friggin leaking again.
Looked behind the Alt and power steering pump and there is spray there, as if it leaking behind there.
Where is this coming from?
I'm about to go nuts!
Thanks
jay
Behind the alternator and powersteering pump is the water line. There is an O-ring where the water pump seal the water pipe so it doesn't leak coolant or spray out. I would say that O-ring went out probably and would be causing it to spray out.
Cool that was it.
I replced the O-ring on the back of the water pump and now i'm good as gold.
Thanks for the help guys.
