Aeromotive AFPR, Please help on my choice of purchase.
1993eclipseGS
3,751
76
Aug 30, 2002
NE, Pennsylvania
I searched for over an hour, I now have a headach, And still no decision made.
I was looking at this one, Being it comes with a gauge and all hardware to install already.
http://www.fuelinjectorclinic.com/cart/AERO_FPKIT1.htm
Product information found here:
http://216.242.145.16/products/product.phtml?p=12
All I need to know is if this will work on my car. I have a 6bolt swapped 2g, So that means I obviously have a 1g engine. I just need to know if I can bolt this right up. It is a 1:1 ratio with fuel/boost.
Please anyone that knows if this will work, And be good for me, Reply as soon as possible. I need to buy this asap.
Thanks alot.
Did you even read the aeromotive product info? It says on the site that the 13105 will rise on a 1:1 ratio when referenced with boost. If you have the right fittings it'll bolt up no problem. And why do you need to buy it so quickly? Are you running a supra pump or something larger like a bosch 044?
I did read the site, And I also stated in my first post that I knew it was a 1:1 ratio, As I posted in the first post of this thread. I just wanted to make sure it would ''fit'' on my car, So to speak. I never purchased an AFPR before for any of my cars, And was always told it would be good to have one, Especially when running a walbro 255lph. I'll be getting 750's-850's in the next few weeks also, So I was pretty sure it would have been a good thing to buy an AFPR. If you don't think so, Care explaining why? I'm not hear to flame anyone, Or get flamed. I asked a simple question, So I expect posts to be positive rather then negative.
Thank you.
I just finished installing my AFPR kit that I got from Import evolution. I got the Stainless kit for 209 and the guage was 25 more. I think total came to like 240 +/- for everything. They include instructions and all fittings including the pipe thread tape and some extra fittings for different mounting options.
I also recommend the import evolution unit, it is available from the home dsmtuners page. total deal, Ryan is cool, and everything you need is in the kit and top quality for CHEAP! good luck
I've heard lots of good things about the ImportEvolution kits mentioned above, and their price is a bit better than the FIC kit you're thinking about, even with the purchase of a gauge, I believe.
However, you were asking if the afpr kit you linked to would work on your car, and no one has answered you. Lol.
From the pics/info you provided....Yes, it should work fine.
The only thing I see as being a potential problem area is the fitting for the "stock DSM fuel rail". 1g fuel rails are not all the same - the 1990s and 1991s each have different "stock" fuel rails (one has a smaller bolt pattern and a more "flat" end - the other has the larger "diamond" shaped fitting as seen in the picture you provided).
Go have a look at your fuel rail and see if it's the right shape. If it is, you should be good to go Otherwise, i'm sure you could find an appropriate fitting from somewhere like ImportEvolution :thumb:
