aem wide ban o2 fuel ratio help
killerclown1984
48
Sep 13, 2008
greenfield park, New York
I have a 1990 talon tsi with 9:1 compression cometic metal head gasket,studded motor arp,t3/t4 50 trim turbonetics turbo,tubular manifold,aem wideband controller 660 injectors,walbro 255 fuel pump,big front mount fimc intercooler fuel pressure regulator
gmaft translator pro set up for speed density IM running 10 pounds of boost at the moment. what should my a/f be from idle to 6000 rpm. :confused:
Depends on the load on the engine and the fuel your using. Under normal cruising and idle, the ECU should maintain ~14.7. Under WOT (91-93 octane) you want to aim somewhere between 11.0-11.5, depending on how your car likes it without knocking.
Lucky bastard:p We only get 91 down here, the wife's Mazdaspeed hates it. That's why my Talon only sees E85...:D
