AEM Users...
Prez
241
Jul 18, 2003
Des Moines, Iowa
Anyone one of you happen to have a timing map you can send me?
Okay how about anyone with a timing map. Just something basic or tuned... Just something to start basing my map off of.
The base map from AEM worked well enough to get my fuel map 95% dialed in. The AEM board will tell you the same.
I'm not using an AEM... :)
I just need the values for the base timing map for my set-up.
then do you even have the program on your computer at least cause you probably wont be able to open anything someone sends you and if you have the program then you should have the base settings from aem.
How about a screen shot of it?
:thumb:
Even the stock timing map values would work if someone knew what they were. I really need this info. Can anyone please help me out?
hope that helps
You my freind deserve a pizza.
Thats the stock map I assume?
should be a 1g 6bolt stock setup, let me know if it doesn't work because the aem website is down and there are a few to pick from.
Cool thanks... when the AEM site comes back up if ya can link me or send the info that would be awesome!!! Thanks a ton!!!
I'm not to sure what you want me to link you to. The site is up and I double checked that what I gave you was from the right ecu (1g) and it is so you should be good with that.
How bout that pizza? :D
That timing map that was posted is a non boosted map or the load breakpoints are set wrong?
my fault, good catch trick engine....
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
