AEM UEGO Install question
sike
59
Dec 18, 2001
Baltimore, Maryland
This is not advanced, but I have no instructions and I'm having problems getting this thing working, and I did not know where to post it. Anyhow, I just got a UEGO single channel controller and aem gauge from 2 different people and I recieved no instructions with the guage. AEM emailed me the instructions, but they were not helpful and I cannot get it to work. I have 6 wires comming from the controller and 2 sets of wires comming from the gauge. One set with 4 wires and one set with 6 that match the colors comming from the controller. I figured the 4 were for the gauge power/ground/light/etc... but the instructions AEM sent me had me thinking otherwise, it did not mention the set of 4 wires at all or the fact that there were 2 seperate sets of wires. So I wired it up the way the instructions led me to believe was correct and I got no display on the gauge. What is the correct way to wire this thing? Thanks.
The guage is supposed to have the controller built in whereas the 10-2301 is supposed to be used sans-gauge with a standalone ECU. The gauge should have two pigtails. One with a connector on it for the sensor and one with 4 wires. The 4 wires are
Red: 12V switched
Black: Chassis grounds
White: 0-5v wideband output for standalone ECUs
Blue: Serial output for RS-232 datalogging
It sounds like you are missing the connector for your sensor. The sensor is a 6 wire sensor. You need to use the connector though, as the sensor has a resistor in it's connector for calibration purposes. Call AEM and see what it will take to get your gauge unit repaired.
The 10-2301 controller should have two pigtails. One with a six wire sensor connector and the other should have 5 wires.
Orange: 0-5v wideband output for standalone ECUs
White: 0-1v narrow band output for use with factory ECU
Brown: Signal ground
Red: 12v Switched power
Black: Battery ground
http://forum.aempower.com/bbs/viewtopic.php?t=4208
Well the controller is 30-2301 for sure. I believe the gauge was designed to work with the controller and is not the one with built in controller. I plan to use this with megasquirt in the future, but I do not have it yet. I'll try wiring it differently tommorow and see what happens.
I have another question about this. I'd imagine, but I am unsure, that the narrowband output from this would be more accurate than the output from a standard narrowband o2 sensor, can anyone confirm this? I could probably find it if I searched, I've seen a few posts just looking around that have mentioned this but I don't believe it was confirmed. Also, the 30-2031 that I have has only 2 wire outputs, one to the sensor and one with a 6 pin connector that connectors to another open wire strand. I think the 6 wires from the gauge go to the 6 wires from the controller, and the red from the 4 wire strand is power for both(sensor and controller), black is ground for both, blue is 0-5v ouput, and white is 0-1v narrow band output. signal. I beleive when I get the MS, I will be able to splice the signal if I want to continue to use the gauge.
The sensor is more accurate than the factory sensor. However, the resolution is still going to be the same since you're taking all the A/F ratio points possible and setting the value to 0-1 instead of 0-5. It will be a much lower resolution than the wideband output.
I guess there is a gauge only option. It's: 30-4113, 30-4123, 30-4213,or 30-4223.
Red= 12v switched power
Black= Chassis Ground
Orange= 0-5v input from controller
Brown= signal ground (connect this to the brown wire on the controller)
White= 0-5v output/passthrough. (connect this to a standalone ECU or other device set to use 0-5v)
Blue= Serial datalogging output.
So you're only going to connect the orange and brown wires together between the two. I'm down in Gaithersburg/Rockville if you need some help with the car. Just PM me.
