Advantages and Disadvantages
FreshTSi
Banned Member
7
Dec 2, 2008
Lancaster, Pennsylvania
Ok so im reading and everyone is talking about Balance shaft elem. kits.
umm, what exactly would i gain or notice if i elem. the balance shaft, and how hard of a task is it to do, i try to all my work my self on my car.
Thanks your fellow
DSMr:talon:
Have you even TRIED using the search button??
This topic has been beaten to death now...
To spoon feed you the info
Advantages
*Less chance of snapping and causing it to tangle up with the timing belt
*Less stress on the crank
*Weight
*Some say they notice power but its very doubtful
Disadvantages
*More incar vibration
*Oil pressure
Those are the main things
Best way to do it, is when the motor is out of the car, some will say just cut the balance shaft belt... but thats a cheap/lazy way ;)
Lol well thanks for the spoon feed, ha and for the info.
I can handle the vibration, but oil press. does it sky rocket or drop off.
Make sure you get a kit with the notched stubby shaft and you don't have to worry about Oil Pres.
I've had the BSE kit on my 4g63 for quite some time.
k i just didnt want to start messin with oil press, well atleast not yet.
How hard of a task is it to do?
I will be doing the same thing since my motor is out right now.
The FFWD kit looks really good.
thanks for the help guys I will go through and do it less stress on my crank is a good enough reason
  • Wanted 6 bolt NT water pipe
    • chrisman287
