Verticaljump1
- 147
- 2
- May 8, 2004
cheyenne,
Wyoming
Hey, first off, the car is going to be a 1992 Eclipse GSX. Excellent condition.
Mods (purchased, but not shipped here yet
3 gauge pillar
boost gauge
2.5"uic gm blow thru set up with 2.5" throttle body elbow
3" gm maf
1g gm maft
walbro 255lph pump
2g ported manifold
3" stainless cat-back
Custom made 3" dp with ported o2 housing
dejon tool dual stage mbc-2a
Ghetto custom 3" intake with K&N
My goal is to get under 13.2 seconds in the 1/4th mile (on pump gas), and 0-60 in under 4.8 seconds (If I'm an ignorant jackass, let me know
). I have around $600 yet, which is enough to buy an act 2600 clutch kit installed, or 550cc injectors with a pocket logger. Which one should I go with? I dont' want the stock clutch to die on me, but I don't want to starve the turbo of the fuel it needs. With stock fuel system, 2nd stage on the boost controller will be set at 17PSI, with the upgraded injectors/pocket logger, I'll set the 2nd stage at 19-20ish (hardly used). Which one would better suit my needs? Thanks for any help you provide, and have a good day!
)3 gauge pillar
boost gauge
3" gm maf
1g gm maft
walbro 255lph pump
2g ported manifold
