Accufab Mustang tb and Tps problem
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
i got a SMIM and accufab mustang tb mounted on. Did a log with dsmlink and found out,that im getting a 28% on closed tps and 87at wot. ried playing around with tps adjustments (tps scale and tps offset) gouldnt get 0% on close tps or 100%at wot. Plus the TPS itself is not moving on a tb,it just bolted down solid....... How da hell i should adjust the tps??
So you can't loosen the 2 bolts holding it down and slide/rotate it either left or right to get proper adjustment?
Thanks guys for a replays, i found the problem ...... It was a bad TPS sensor :ohdamn:,was freakin around the whole day, and after one bottle of corona great thing came into my mind,to get a new tps,and now at idle im getting 0% and wot 100% Big thanks to Corona LOL
  • Wanted 6 bolt NT water pipe
    • chrisman287
