Acceleration stall/cut out...
2GDSM
150
Feb 15, 2004
Springfield, Illinois
I got a GS-T Auto, when I was in first tonight accelerating it felt as if there was a power loss, and sort of cut out a bit, nothing really noticable, but I drive my car alot, and know when there is a difference. I need a PCV Valve, and o2 senser, just wondering if these could be the reason. It felt the same as when you take the recirculate off the BOV and try to drive hard. Any info would be helpful, thanks.
WOW, you need to be able to deal with one problem at a time. Throwing all these problems together can make a mess. Needing a O2sensor and a pcv if its cloged can really hinder performance. If your car still feels like this after they are fixed (you can even do this before it wont hurt) check for BOOST leaks. Guaranteed you have some. Then check your isc motor.
If you need help with these things look at vfaq.com
scott
    • Sdcryan1
