Dryppical
- 105
- 17
- Apr 5, 2023
East Helena,
Montana
I have finally been able to drive my car and there's this issue where the car feels sluggish.
Kind of hard to explain. You floor it or give it mostly full throttle and you slowly accelerate. Then the car gets up higher in the rpm and you have to let off a little bit or else it will like fall on its face and if you have too much gas its almost like it goes into neutral, but once you do that, it starts moving pretty fast I think.
Then you shift into second and your back to square one again. If you floor it/give mostly full throttle, it will just like fall on its face. It slowly accelerates until a point, then you have to let off a little bit. You have to slowly ease into it. Just feels like it doesn't have the power it should.
I did some logs, I don't really know how to use DSMLink yet or what I'm even looking at. Maybe these will help and if you guys need a log under different conditions or something, I'll go do one. I've just never had the chance to actually use DSMLink.
My car drives fine under normal conditions if you're not giving it the gas. The car idles and runs good, at least I think it does. I have done a boost leak test and it holds 20 psi no problem. Takes like 3 minutes to bleed it all off. I fixed the few small leaks it had. I set my AFPR to 43 psi by turning the pump on with DSMLink. New fuel filter and fresh 91 in the tank. I also ran some Seafoam through it to clean the injectors a bit. All fresh fluid and filters including transmission.
Any help is greatly appreciated
